We are trying to use 2 stm32wb5m chips on stm32 b-u585i-IOT02A boards to make a bluetooth connection between the 2 boards. The example code available (BLE_AT_CLIENT) for using bluetooth does not work. Searching for info about the chip and AT commands.
RHoeg.1
Remy ISSALYS
You can find many information about AT commands on the following wiki page:
https://wiki.st.com/stm32mcu/wiki/Connectivity:STM32WB_AT_Server
An application note on it is also available:
https://www.st.com/resource/en/application_note/an5379-examples-of-at-commands-on-stm32wb-series-microcontrollers-stmicroelectronics.pdf
Best Regards
