Updating advertisement packet after waking up from standby mode (WB15CC)
My application (WB15CC) stays most of the time in standby mode transmitting the advertainment packet. After a couple of minutes, the advertainment packet must be updated. When I try to update the packet after waking up from the standby mode, the firmware hangs on any of the GAP API routines, e.g. aci_gap_set_non_discoverable(), aci_gap_set_discoverable() or aci_gap_update_adv_data().
I've edited the startup code by adding the CPUcontextSave and CPUcontextRestore routines, similar to the BLE_HeartRate example, to restore the CPU context when waking up from the standby mode. Indeed, the CPU is restored correctly I am able to register a new task inside the UTIL_SEQ_PostIdle() routine, however my task can't update the packet.
Can someone elucidate me what are the steps to update the advertisement packet when coming out of the standby mode?
