STM32WL5x device errata clarification needed for DMA stream locked when transferring data to/from USART
CLang.7
The errata sheet ES0500 - Rev 4 mentions a workaround for 2.8.3 DMA stream locked when transferring data to/from USART where bit 20 of register DMA_SxCR shall be set. This register is not mentioned in the reference manual and not in the respective header files of STM32CubeWL.
Q1: Is the mentioned errata relevant for the STM32WL5x family?
If yes:
Q2: How is the workaround implemented, e.g. where is register DMA_SxCR?
Thanks!
Carsten
Louis AUDOLY
Hello @CLang.7​ welcome to the community,
Thank you for pointing out this issue. This section 2.8.3 do not concern the STM32WL family, we will correct the errata sheet.
Louis
Louis AUDOLY
Louis
GPają.1
@Louis AUDOLY​ The same problem as described by Clang.7 occur in errata ES0506 - Rev 4.
I have seen section 2.8.3 was removed from ES0500 so it should be corrected in ES0506 also. However problem with DMA still is present on STM32WLE5CCU6. Is there any workaround?
