STM32WB55 custom app event not call
Tthur.1
Hi, in custom_app.c file, my event WRITE_NO_RESP_EVT is not call in the function Custom_STM_App_Notification. Where are the BLE notification in custom app ?
GFell.1
Hi, I have got the same problem. WRITE_NO_RESP_EVT in custom_app.c is never called.
Did you find a solution for the problem?
Tthur.1
Yes, i have modify the Custom_STM_Event_Handler function
static SVCCTL_EvtAckStatus_t Custom_STM_Event_Handler(void *Event)
 SVCCTL_EvtAckStatus_t return_value;
 hci_event_pckt *event_pckt;
 evt_blecore_aci *blecore_evt;
 aci_gatt_attribute_modified_event_rp0 *attribute_modified;
 aci_gatt_read_permit_req_event_rp0  *read_req;
 Custom_STM_App_Notification_evt_t   Notification;
 /* USER CODE BEGIN Custom_STM_Event_Handler_1 */
 /* USER CODE END Custom_STM_Event_Handler_1 */
 return_value = SVCCTL_EvtNotAck;
 event_pckt = (hci_event_pckt *)(((hci_uart_pckt*)Event)->data);
 switch(event_pckt->evt)
  case HCI_VENDOR_SPECIFIC_DEBUG_EVT_CODE:
   blecore_evt = (evt_blecore_aci*)event_pckt->data;
   switch(blecore_evt->ecode)
    case ACI_GATT_ATTRIBUTE_MODIFIED_VSEVT_CODE:
     /* USER CODE BEGIN EVT_BLUE_GATT_ATTRIBUTE_MODIFIED_BEGIN */
     /* USER CODE END EVT_BLUE_GATT_ATTRIBUTE_MODIFIED_BEGIN */
     attribute_modified = (aci_gatt_attribute_modified_event_rp0*)blecore_evt->data;
     if(attribute_modified->Attr_Handle == (CustomContext.CustomUart_TxHdle + CHARACTERISTIC_DESCRIPTOR_ATTRIBUTE_OFFSET))
      return_value = SVCCTL_EvtAckFlowEnable;
      /* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1 */
      /* USER CODE END CUSTOM_STM_Service_1_Char_1 */
      switch(attribute_modified->Attr_Data[0])
       /* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1_attribute_modified */
       /* USER CODE END CUSTOM_STM_Service_1_Char_1_attribute_modified */
       /* Disabled Notification management */
       case (!(COMSVC_Notification)):
        /* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1_Disabled_BEGIN */
        /* USER CODE END CUSTOM_STM_Service_1_Char_1_Disabled_BEGIN */
        Notification.Custom_Evt_Opcode = CUSTOM_STM_UART_TX_NOTIFY_DISABLED_EVT;
        Custom_STM_App_Notification(&Notification);
        /* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1_Disabled_END */
        /* USER CODE END CUSTOM_STM_Service_1_Char_1_Disabled_END */
        break;
       /* Enabled Notification management */
       case COMSVC_Notification:
        /* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1_COMSVC_Notification_BEGIN */
        /* USER CODE END CUSTOM_STM_Service_1_Char_1_COMSVC_Notification_BEGIN */
        Notification.Custom_Evt_Opcode = CUSTOM_STM_UART_TX_NOTIFY_ENABLED_EVT;
        /* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1_COMSVC_Notification_END */
        /* USER CODE END CUSTOM_STM_Service_1_Char_1_COMSVC_Notification_END */
        break;
       default:
        /* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1_default */
        /* USER CODE END CUSTOM_STM_Service_1_Char_1_default */
       break;
     } /* if(attribute_modified->Attr_Handle == (CustomContext.CustomUart_TxHdle + CHARACTERISTIC_DESCRIPTOR_ATTRIBUTE_OFFSET))*/
     else if(attribute_modified->Attr_Handle == (CustomContext.CustomUart_RxHdle + CHARACTERISTIC_VALUE_ATTRIBUTE_OFFSET))
      /* USER CODE BEGIN CUSTOM_STM_Service_1_Char_2_ACI_GATT_ATTRIBUTE_MODIFIED_VSEVT_CODE */
      Notification.Custom_Evt_Opcode = CUSTOM_STM_UART_RX_WRITE_NO_RESP_EVT;
      Notification.DataTransfered.Length=attribute_modified->Attr_Data_Length;
      Notification.DataTransfered.pPayload=attribute_modified->Attr_Data;
      /* USER CODE END CUSTOM_STM_Service_1_Char_2_ACI_GATT_ATTRIBUTE_MODIFIED_VSEVT_CODE */
     } /* if(attribute_modified->Attr_Handle == (CustomContext.CustomUart_RxHdle + CHARACTERISTIC_VALUE_ATTRIBUTE_OFFSET))*/
     /* USER CODE BEGIN EVT_BLUE_GATT_ATTRIBUTE_MODIFIED_END */
     /* USER CODE END EVT_BLUE_GATT_ATTRIBUTE_MODIFIED_END */
     break;
    case ACI_GATT_READ_PERMIT_REQ_VSEVT_CODE :
     /* USER CODE BEGIN EVT_BLUE_GATT_READ_PERMIT_REQ_BEGIN */
     /* USER CODE END EVT_BLUE_GATT_READ_PERMIT_REQ_BEGIN */
     read_req = (aci_gatt_read_permit_req_event_rp0*)blecore_evt->data;
     if(read_req->Attribute_Handle == (CustomContext.CustomBatHdle + CHARACTERISTIC_VALUE_ATTRIBUTE_OFFSET))
      /*USER CODE BEGIN CUSTOM_STM_Service_2_Char_1_ACI_GATT_READ_PERMIT_REQ_VSEVT_CODE_1 */
      /*USER CODE END CUSTOM_STM_Service_2_Char_1_ACI_GATT_READ_PERMIT_REQ_VSEVT_CODE_1*/
      aci_gatt_allow_read(read_req->Connection_Handle);
      /*USER CODE BEGIN CUSTOM_STM_Service_2_Char_1_ACI_GATT_READ_PERMIT_REQ_VSEVT_CODE_2 */
      /*USER CODE END CUSTOM_STM_Service_2_Char_1_ACI_GATT_READ_PERMIT_REQ_VSEVT_CODE_2*/
     } /* if(read_req->Attribute_Handle == (CustomContext.CustomBatHdle + CHARACTERISTIC_VALUE_ATTRIBUTE_OFFSET))*/
     /* USER CODE BEGIN EVT_BLUE_GATT_READ_PERMIT_REQ_END */
     /* USER CODE END EVT_BLUE_GATT_READ_PERMIT_REQ_END */
     break;
    case ACI_GATT_WRITE_PERMIT_REQ_VSEVT_CODE:
     /* USER CODE BEGIN EVT_BLUE_GATT_WRITE_PERMIT_REQ_BEGIN */
     /* USER CODE END EVT_BLUE_GATT_WRITE_PERMIT_REQ_BEGIN */
     /* USER CODE BEGIN EVT_BLUE_GATT_WRITE_PERMIT_REQ_END */
     /* USER CODE END EVT_BLUE_GATT_WRITE_PERMIT_REQ_END */
     break;
    /* USER CODE BEGIN BLECORE_EVT */
    /* USER CODE END BLECORE_EVT */
    default:
     /* USER CODE BEGIN EVT_DEFAULT */
     /* USER CODE END EVT_DEFAULT */
     break;
   /* USER CODE BEGIN EVT_VENDOR*/
   /* USER CODE END EVT_VENDOR*/
   break; /* HCI_VENDOR_SPECIFIC_DEBUG_EVT_CODE */
   /* USER CODE BEGIN EVENT_PCKT_CASES*/
   /* USER CODE END EVENT_PCKT_CASES*/
  default:
   /* USER CODE BEGIN EVENT_PCKT*/
   /* USER CODE END EVENT_PCKT*/
   break;
 /* USER CODE BEGIN Custom_STM_Event_Handler_2 */
 /* USER CODE END Custom_STM_Event_Handler_2 */
 return(return_value);
}/* end Custom_STM_Event_Handler */
GFell.1
Thanks a lot, it works!
