STM32WB55 CRC Failure in Write Response (Stack 1.23.0)
JBakalor
We are seeing an issue where the STM32WB55 module is failing to send a valid write response.  The write response is attempted but based on the packet logs, the CRC is failing.  This results in the central (app running on Android) forcing a disconnection. This always happens on the first connection to the module and is reproducible.  We are using a very lightly modified version of the Cable replacement example.  Pcap and project attached
STTwo-32
Hello @JBakalor
Do you have the same issue using the exact BLE_CableReplacement example.
Best Regards.
STTwo-32
