STEVAL-FKI868V2 for LoraWan
Options
‎2023-10-16 2:19 PM
Hi, Can I connect to the LoraWan network using the STEVAL-FKI868V2 evaluation board connected to the NUCLEO L053R8 board? Can this be done without using additional modules?
Options
‎2023-10-16 2:26 PM
Pretty sure the S2-LP doesn't support LoRa modulation, that's patented by Semtech
https://www.st.com/resource/en/datasheet/s2-lp.pdf
Options
‎2023-10-16 2:26 PM
Options
‎2023-10-19 6:22 PM
