New design based on STM32WB55CGU6 Microcontroller
GKhar.2
I have a new design based on STM32WB55CGU6 Microcontroller. I wanted to use the MLPF-WB55-1E03 IPD Device for Maching Network. However, the device seems to be out of stock world wide.Can I replace it with MLPF-WB55-02E3?
Remi QUINTIN
 The MLPF-WB55-01E3 IPD has been tuned to match with QFN48 and QFN68 packages
The MLPF-WB55-02E3 IPD has been tuned to match with the WLCSP100 package
As the QFN and WLCSP packages do not have the same output impedance, the IPD is different.
So, if you use the MLPF-WB55-02E3 with a STM32WB55CGU6 microcontroller, it will work but you will not obtain the best RF performances.
