2025-12-11 5:31 AM
Is it possible to add MotionFx to an STM32WB09TEF7TR MCU?
According to the table on page 6 of this document:
https://www.st.com/resource/en/brochure/sensor_libraries_software_pack_for_stm32cube.pdf
MotionFx is available on Cortex M0+
However when trying to add this in CubeMx I get the warning "This component cannot be used as it has device or context compatibility issues.
2025-12-11 6:20 AM
Indeed, UM2220 Getting started with MotionFX sensor fusion library in X-CUBE-MEMS1 says that Cortex-M0+ is supported:
From a quick glance at that, CM0+ seems to be a bit of a special case - so maybe that's not supported by CubeMX ?
