is it possible to make a FOTA on an STM32L432KB?
NItin Kanani
Posted on December 22, 2017 at 06:36
if is it possible then which memory are use for store the hex file.
external flash or system flash?
please suggest other option also.
6 REPLIES 6
Uwe Bonnes
Chief
Posted on December 22, 2017 at 10:08
What is 'FOTA'?
Posted on December 22, 2017 at 10:48
Firmware Over The Air
Basically remote firmware update.
Yes, stage the new firrmware somewhere in your design. If enough internal flash then use that.
Posted on December 22, 2017 at 11:28
its Firmware Over the Air
Posted on December 22, 2017 at 15:20
I would tend to use a binary packaging method, the .HEX type files are about 2.4x larger than necessary.
What is the 'air' in your delivery strategy?
Posted on December 23, 2017 at 07:35
i will use LTE Module for that
Posted on December 23, 2017 at 19:13
So perhaps the easiest would be a binary file server via HTTP or FTP
