how to produce analog output with STM32WB5MMGH6
JulienD
I need to output an analog audio signal from STM32WB5MMGH6. I did not see any DAC on this chip so my questions are:
Is there another peripheral which can do this job that I didn't find in the datasheet ?
Also, if I can't do it with a dedicated peripheral, can you confirm that  a codec is the device I need as interface?
Another solution?
Julien
AScha.3
if you dont need top audio quality, the "standard" way is to use a timer->pwm + R_C lowpass filter, to generate analog signal.
for "hi-fi " you need a audio dac, like a PCM5102a . + connect with SAI .
