2025-08-30 2:18 AM - last edited on 2025-09-01 3:07 AM by Andrew Neil
I am using the 2 stm32wb55rev6 controller and i have uploaded the latest version of the FUS and the stack ble full firmware.I am not able to connect to the client by using the server.
2025-08-30 10:37 AM
Hello @TejasK
I suggest you follow and verify that you are applying all the recommandations of the AN5289 for both client and server nodes.
Best Regards.
STTwo-32
2025-08-30 10:37 AM
Hello @TejasK
Best Regards.
STTwo-32
