Hi I am using Nucleo-WL55jc1 board. One is programmed as concentrator, other is programmed as sensor node. Currently the software is programmed for 14 sensors nodes How can I extend it to about 200 sensor node
Currently I am using the firmware LocalNetwork_Concentrator and LocalNetwork_Sensor.
The maximum Sensor nodes are 14. I wish to connect around 200 LocalNetwork_sensor.
Kindly help me to make the required changes in the software.
