2021-10-29 8:52 AM
In AN4879 FAQ it is stated to check "Table 3. USB implementation in STM32 devices" whether the USB_DP line has an embedded pull-up resistor.
STM32WB55 is not in that list. Can you confirm if the STM32WB55 has embedded pull-up resistor on USB_DP or not?
2021-10-29 9:09 AM
Per the reference manual, it has an embedded resistor on USB_DP.
USB connect / disconnect capability (controllable embedded pull-up resistor on USB_DP line)
2021-11-05 8:44 PM
YES!the STM32WB55 has embedded pull-up resistor on USB_DP.
