ONDOU
Visitor II
September 18, 2018
Can we create a firmware wich mixes the Lora stack (I-Cube-LRWAN1) and the Sigfox stack (X-Cube-SFOX)
  • September 18, 2018
  • 0 replies
  • 525 views
Hello everybody,
I'm new on this platform.
Currently, I am testing separately, the working of the Lora and Sigfox stacks on the B-L072Z-LRWAN1 evaluation board.
The sample program I use for each stack is the AT Modem. And each stack works very well.
I want now, create a program/firmware wich mixes both stacks. That is, a program that allows with the use of an AT command, to switch from one stack to another. All in one program
So, is there already a program/firmware of this kind?
Thank you in advance for your answers
