2019-05-12 8:46 PM
Hi All,
May i check with you all on the following question,
1. The data needs to be sent to server/cloud, therefore a gateway is required. Does ST have a solution on the BLE gateway?
2. If the BLE Module is used, mesh topology will be employed. Does ST provide any support on the mesh firmware?
Much thanks.
