2024-05-28 11:34 PM - last edited on 2024-06-07 7:26 AM by Tesla DeLorean
When combining the standby and OTA samples (listed below), in some cases, the OTA sample is started at the timing of standby wakeup.
・PWR_STANDBY_RTC
・BLE_Ota
In my understand, whether the standby or OTA sample is started is determined by the first 4 bytes of SRAM1's address.
Is there a case where SRAM1 becomes an undefined value in the standby, resulting in the OTA being started?
2024-06-07 6:56 AM
Hi @TH5
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Billy
2024-06-07 7:28 AM
It's unclocked but should maintain content. Its typically the startup code that could trash it. But you can likely use a area that's unused and untouched. Should have a mechanism to check the integrity of data stashed there.
