B-L072Z-LRWAN1 ERROR dev_nonce_too_small
RSheetz
Dear ST Community, Dear ST Team.
For a evaluation of the chip i would like to try over LoRaWAN Communtication to set a LED on and off.
Sadly on the  tutorial program LoRaWAN_End_Node i get the ERROR: dev_nonce_too_small. The Problem is that on the Documentation from the things Stack i should contact the device’s manufacturer to find out the correct LoRaWAN MAC and PHY versions
I even try out to find a older version of the extension but i dont find any.
So im sitting on a dead end and im glad to hear some ideas or information about that topic
Thanks for your help
RSheetz
RSheetz
So i have found the mistake, i should set the LoRaWAN Version under the Number 1.0.4 on the aplication level so i use now 1.0.3 and the Join Procedure works fine!
Pls Close this Post.
Thx RSheetz
