Whether the server logs when TouchGFX Designer downloads board setup and example
‎2023-05-25 10:35 PM
I understand that when TouchGFX Designer starts, it connects to the server and downloads board setup and example.
I want to know that server logs or not because my company security policy.
Thank you and regards
- Labels:
TouchGFX
‎2023-06-13 6:00 AM
Hello @sini​,
The logs of TouchGFX Designer are contained inside C:\Users\username\AppData\Roaming\TouchGFX-4.21.4\TouchGFXDesigner.log.
There you will be able to see most things that happen during TouchGFX Designer startup, connection to servers and basically almost all that happens when you use the tool.
/Yoann
‎2023-06-13 6:00 AM
Hello @sini​,
/Yoann
