TouchGFX dynamic graph
we use GraphWrapAndClear and update the graph every 1 second, it works fine. but the problem is after running for long time (over 12 hours), there is some short line flicker on the different part of screen. if we move out of this screen, and come back, the flicker disappeared, every thing is fine again. it seems running longer time cause the problem. Do you have the similar problem? I am using TouchGFX 4.17.
