TouchGFX color and other defines in designer.
MM..1
Chief III
Hi, maybe i ask this some years ago, but still not resolved.
In designer now cant create defines list for use instead constant numbers. Then can be quickly managed all objects.
Now for example i have designs with 150 labels and set some level of white color on every.
After design presented boss say require more darker or lighter texts, then start hard job click on every object and change color, instead we need change one define.
Exist any way to do it now, or is planned in next release ??
11 REPLIES 11
GaetanGodart
Thank you for your answer @JTP1 .
The theme solution seems hard to set up indeed.
We will discuss @MM..1 's proposition of constants inside Designer this week.
Gaetan Godart
Software engineer at ST (TouchGFX)
GaetanGodart
Hello @MM..1 and @JTP1 ,
The feature has been discussed and we will try to implement solutions to modify multiple elements at once and to set defines from Designer. However, there is no timeline set for it yet.
Gaetan Godart
