TouchGFX 4.22 simulator not working?
Rodo
Hi all,
I upgraded to TouchGFX 4.22 from 4.21 and now the simulator doesn't work. It was fine with the projects before and I haven't change much. The log (below) shows that it can't find cmsis_os.h in model.cpp. It seems to be the same error in the other projects. The file is not missing. I can "go to declaration" of cmsis_os.h inside model.cpp and it opens up cmsis_os.h. I need that header because I'm checking a freeRTOS queue inside Model::tick()
What's the problem? Thanks
Run Simulator
    Generate
        Done
    Generate Assets
        make -f simulator/gcc/Makefile assets -j8
        Reading ./application.config
        Reading ./target.config
        Done
    Post Generate
        touchgfx update_project --project-file=simulator/msvs/Application.vcxproj
        Done
    Post Generate Target
        .cproject file: ../STM32CubeIDE/.cproject
        Writing STM32CubeIDE project file: ../STM32CubeIDE/.project
        Writing STM32CubeIDE project file: ../STM32CubeIDE/.cproject
        Done
    Compile
        make -f simulator/gcc/Makefile -j8
        Compiling gui/src/settingscreen_screen/settingScreenPresenter.cpp
        Compiling gui/src/settingscreen_screen/settingScreenView.cpp
        Compiling gui/src/principalscreen_screen/principalScreenView.cpp
        Compiling gui/src/principalscreen_screen/principalScreenPresenter.cpp
        Compiling gui/src/model/Model.cpp
        Compiling gui/src/common/FrontendApplication.cpp
        Compiling generated/gui_generated/src/settingscreen_screen/settingScreenViewBase.cpp
        Compiling generated/gui_generated/src/principalscreen_screen/principalScreenViewBase.cpp
        In file included from gui/src/model/Model.cpp:1:0:
        gui/include/gui/model/Model.hpp:5:10: fatal error: cmsis_os.h: No such file or directory
         #include <cmsis_os.h> // for RTOS queues
        compilation terminated.
        generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/model/Model.o' failed
        make[2]: *** [build/MINGW32_NT-6.2/gui/src/model/Model.o] Error 1
        make[2]: *** Waiting for unfinished jobs....
        In file included from generated/gui_generated/include/gui_generated/common/FrontendApplicationBase.hpp:8:0,
                         from gui/include/gui/common/FrontendApplication.hpp:4,
                         from generated/gui_generated/include/gui_generated/settingscreen_screen/settingScreenViewBase.hpp:7,
                         from gui/include/gui/settingscreen_screen/settingScreenView.hpp:4,
                         from gui/src/settingscreen_screen/settingScreenView.cpp:1:
                         from gui/src/settingscreen_screen/settingScreenPresenter.cpp:1:
                         from generated/gui_generated/include/gui_generated/principalscreen_screen/principalScreenViewBase.hpp:7,
                         from gui/include/gui/principalscreen_screen/principalScreenView.hpp:4,
                         from gui/src/principalscreen_screen/principalScreenView.cpp:1:
        generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/principalscreen_screen/principalScreenView.o' failed
        make[2]: *** [build/MINGW32_NT-6.2/gui/src/principalscreen_screen/principalScreenView.o] Error 1
        generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/settingscreen_screen/settingScreenView.o' failed
        make[2]: *** [build/MINGW32_NT-6.2/gui/src/settingscreen_screen/settingScreenView.o] Error 1
        generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/settingscreen_screen/settingScreenPresenter.o' failed
        make[2]: *** [build/MINGW32_NT-6.2/gui/src/settingscreen_screen/settingScreenPresenter.o] Error 1
                         from gui/src/principalscreen_screen/principalScreenPresenter.cpp:1:
        generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/principalscreen_screen/principalScreenPresenter.o' failed
        make[2]: *** [build/MINGW32_NT-6.2/gui/src/principalscreen_screen/principalScreenPresenter.o] Error 1
                         from generated/gui_generated/src/principalscreen_screen/principalScreenViewBase.cpp:4:
                         from gui/src/common/FrontendApplication.cpp:1:
        generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/generated/gui_generated/src/principalscreen_screen/principalScreenViewBase.o' failed
        make[2]: *** [build/MINGW32_NT-6.2/generated/gui_generated/src/principalscreen_screen/principalScreenViewBase.o] Error 1
                         from generated/gui_generated/src/settingscreen_screen/settingScreenViewBase.cpp:4:
        generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/common/FrontendApplication.o' failed
        make[2]: *** [build/MINGW32_NT-6.2/gui/src/common/FrontendApplication.o] Error 1
        generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/generated/gui_generated/src/settingscreen_screen/settingScreenViewBase.o' failed
        make[2]: *** [build/MINGW32_NT-6.2/generated/gui_generated/src/settingscreen_screen/settingScreenViewBase.o] Error 1
        generated/simulator/gcc/Makefile:155: recipe for target 'generate_assets' failed
        make[1]: *** [generate_assets] Error 2
        simulator/gcc/Makefile:32: recipe for target 'all' failed
        make: *** [all] Error 2
        Failed
    Failed
Smartembedded
When building the simulator no hardware and embedded stuff such as freeRTOS are needed.
Try change the code like this in places where you have references to the platform :
#ifndef SIMULATOR
#endif
