STemWin Library problem while Rotating LCD
Options
2016-02-12 4:38 AM
Posted on February 12, 2016 at 13:38
I am currently working with STM32F439ZI microcontroller and interfaced SPI LCD having 144x128 resolution with MCU. STemWin library is used to run my GUI on LCD. Currently I am facing issue of how to rotate LCD to 90 deg anti-clockwise and 90 deg clockwise. Currently in my code, I have used ''GUI_DEVICE_CreateAndLink(GUIDRV_LIN_1, GUICC_1, 0, 0)'' API and it works fine. But now I want to rotate my LCD screen. To rotate the screen, I am using ''GUI_DEVICE_CreateAndLink(GUIDRV_LIN_OXY_1, GUICC_1, 0, 0)'' API but I am getting Linker error like ''no definition for GUIDRV_Lin_OXY_1_API''. Also I have tried with set orientation API but I got distorted screen after using this API. Is there any other way available to rotate the LCD screen? Can you please give some suggestions/guidance regarding how to rotate LCD using STemWin Library? Any help in this case is highly appreciable. Thanks, Nipam #lcd #stm32 #guidrv_lin #stemwin
0 REPLIES 0
