Scroll animation
heyo
Does in the TouchGFX is scrollable container animation? I use doScroll() function but it would be nicer if it scrolls automatically with animation or smoothly.
Hello @heyo ,
Scrollable container does not provide a function for animation directly, however, you can use Easing Equations to calculate the deltas to have a smoother scroll. You can use a method similar to this:
#include "touchgfx/EasingEquations.hpp"  //To have Easing Equations
//If new item is inserted, set the animationIsRunning to true
void Screen1View::handleTickEvent()
    if (animationIsRunning)
        scrollWithAnimation();
void Screen1View::scrollWithAnimation()
    const int duration = 50;
    if (animationCounter <= duration)
        int16_t delta = EasingEquations::linearEaseIn(animationCounter, 0, /* The final scroll value */, duration);
        scrollableContainer1.doScroll(0, delta);  //If scrolling vertically
        scrollableContainer1.invalidate();
        animCounter++;
    else
        animationCounter = 0;
        animationIsRunning = false;
I hope this helps you!
Mohammad MORADI
Hello @heyo ,
        animCounter++;
    else
Mohammad MORADI
Sorry but it's working like doScroll() function..
If you press insert new item rapidly, there might be a chance that the animation is not ended yet and the new item is added quickly. You have to allow the animation steps to end before adding a new item
Mohammad MORADI
