2018-12-24 10:24 PM
Hi
Another problem with Animated Image example at win 10
log file is enclosed ,
I could run the same example at win 7
Can anybody help
2019-01-02 2:40 AM
Hi!
I'm seeing a few different errors in the logfile. Before getting into those - What happens with your application on Windows 10?
Thanks!
2019-01-02 2:47 AM
2019-01-02 2:49 AM
Thank you for the update!
And you're using TouchGFX 4.10.0 ?
2019-01-02 2:53 AM
Yes but I tried 4.9.3 also
2019-01-02 2:55 AM
<duplicate post>
2019-01-02 2:55 AM
Thanks!
Did you create the application itself on a windows 7 machine and are now trying to run it on Win10?
2019-01-02 2:58 AM
I have win 7 at my home
I tried example and new project without any problem at win 7
At work I have another pc with win 10 .I couldnt simulate or compile anything here
2019-01-02 3:55 AM
I just tried the AnimatedImage example with TouchGFX 4.10.0 on my Windows 10 machine - No problems here.
Which language is your Windows 10 at work? And just to be 100% sure - This is your procedure?
1) Start designer
2) Create new application with Simulator Application Template and Animated Image UI Template
3) "Run Simulator" gives you the error in your log
Thanks!
Best regards
Martin
2019-01-02 4:00 AM
Hi
I tried again as you said
Error during code generation
and same error window
