2021-09-13 11:30 PM
Sample usage:
I want to have different settings when working in hardware vs working on simulator
2021-09-14 4:42 AM
If you wish to add code only for when running with the simulator you can wrap the particular code (UI components and logic) in something like this:
#ifdef SIMULATOR
#endifDon't know if there is the equivalent for just running on hardware.
/Romain
2021-09-14 4:42 AM
#ifdef SIMULATOR
/Romain
2021-09-15 9:15 PM
Thank you @Romain DIELEMAN
Anyway for my knowledge, while the macro seems to work, but I could not see in the simulator .sln project code it is defined. So where is this macro 'SIMULATOR' defined?
2021-09-16 2:03 AM
I don't know to be honest, I'll try to check
/Romain
