Is it possible to zoom in using two fingers in Touch GFX Designer?
TN
Hi, I have a question about the touch operation in the TouchGFX Designer.
I want to enlarge the display by spreading two fingers like a smartphone browser, but I can't find it even if I check the demo screen.
If it is possible to operate with two fingers, please point me to a page showing a usage example.
Osman SOYKURT
Hello @TN ,
TouchGFX doesn't support multi touch. The TouchController interface is based on a single set of coordinates and whether a touch was registered or not.
     * Samples the position of the mouse cursor.
     * @param [out] x The x coordinate.
     * @param [out] y The y coordinate.
     * @return True if touch detected, false otherwise.
    bool doSampleTouch(int32_t& x, int32_t& y) const;
Osman SOYKURT
Osman SOYKURT
Hello @TN ,
Osman SOYKURT
Thank you for answering, @Osman SOYKURT .
I understand that it is not possible to distinguish between multiple coordinates.
I will consider zooming in using other touch operations.
