io ports not controlling
kishor
sir we are using the stm32f7508-dk board , code is generated  through touchgfx working properly (display part). when add led toggle code , led not toggling ,
GaetanGodart
Hello @kishor ,
I guess you want to toggle the led by pressing a digital button on the display.
To interact with something outside the screen (ex : the hardware or another screen), you should use the Model-View-Presenter Design Pattern used by TouchGFX.
Here is the documentation about the MVP Design Pattern :  MVP design pattern
Here is the tutorial using the MVP Design Pattern : MVP tutorial
There is also a Youtube video about that wher Gustavo show how to use a harware button to toggle a rectangle on the screen but e also shows how to use a digital buttn on the screen to toggle a hardware led : TouchGFX GUI and Hardware Interaction
Sharing the "led toggle code" and your process cold help us understand the issue.
Hope this helps.
Don’t hesitate to give us a feedback or give more precisions and tell us if the issue is solved! :smiling_face_with_smiling_eyes:
Gaetan Godart
Software engineer at ST (TouchGFX)
