Improving the TouchGFX experience (Fixing broken links in the tool chain)
Martin KJELDSEN
Chief III
Hi everyone!
I'm kicking off a parallel effort to improve the experience using TouchGFX as far as general ST tool chain is concerned. There are links i cannot fix (though i can suggest improvements) and there are some that i can.
So, what are the major pain points in using this rather complicated tool chain (TouchGFX Designer, CubeMX, CubeIDE, CubeProgrammer, etc)?
  • Which improvements would you like to see to make using TouchGFX easier when it come to integration and tool chain? (Specific framework/designer inputs are also welcome and i'll forward those, although this survey is mostly concerned with how to improve integration between tools).
  • What are you typically struggling with when you struggle?
Thanks!
Best regards,
Martin
20 REPLIES 20
Hi Martin,
If you change the spreadsheet please make it something a non-technical user can edit if possible. Translations are usually not done by programmers!
Thanks, John
