Import XD file to touchgfx
JayZee
I am designing a product with touchgfx, my UI designer is providing a full user interface design in XD format. He is using Adobe XD for this.
Is there any way I can import this into Touchgfx?
Hello @JayZee ,
I'm no expert in Adobe XD, so I'm not sure what type of outputs it can gives you. But, if you can import your assets and elements defined in your UI project as png files or svg, then you can use them in TouchGFX with no issues. Otherwise, TouchGFX does not support XD format directly.
I hope this helps,
Good luck
Mohammad MORADI
