how to interface CAPACITIVE touch display(INNOLUX AT043TN24 V.7) have four analog pin with stm32f429 please give me example code.
GagandeepSingh.6
waclawek.jan
If it has four analog pins, it is most likely resistive rather than capacitive touchscreen.
Usually, touchscreens are interfaced using dedicated chips. It's not impossible to use the mcu directly or with little common extra hardware e.g. opampas; but it's far from being simple and you won't be able to find many examples.
Have a look at the 'F429 DISCO board, that one uses a resistive touchscreen and a dedicated controller (although the older ST controller is obsolete).
