How to get keypad input as hex
GunGo
Hello everyone.
I Tried shared widget keypad with numbers. My question is how can get to hex from wildcard Unicode::UnicodeChar. Idea is to send simple CANBus message where is 9 wildcard input buffers and after char input it saves chars to a gui and saves hex to buffers ID[9] and Data[8]
In GUI widget input
ID[0FFAB] DATA[11][00][AB][02][03][00][FF][BE]​
And it saves in bufers like:
ID[9] = {0x00000FFAB}​
Data[8]={0x11,0x00,0xAB,0x02,0x03,0x00,0xFF,0xBE}​
Yoann KLEIN
Hello @GunGo​,
Did you take a look at the documentation of the Unicode class ?
Maybe you can find something useful there.
/Yoann
Yoann KLEIN
Can you specify which function can format unicode char A to integer hex A or dec 10
Becouse direct convert from unicode to hex is 0x41
I use Tgfx​ 4.21
