How can I save data in QSPIFLASH while GUI is running? (Use QSPIFLASH to supply GUI)
2021-05-06 12:12 AM
Hi, I has some questions about how to save data in QSPIFLASH.
I notice that when touchGFX is running,the QSPI would be set into memory-mapped mode and status would be busy.User can not write data in memory-mapped mode.
I had already assign address for user data.
If I create a task stop GUI task and switch QSPI into indirect mode in order to handle data saving . After saving data , task will switch QSPI into memory-mapped mode and release the waitting of GUI task.
Am I going thr right way?
Can GUI still running correctly after handled by task?
If my saving time last for some seconds , Is that means GUI should be no animation after QSPI swtich into memory-mapped mode?
Thanks!
