How can I get earlier versions of STemWin library from ST?
Ahaji.1
Hello everyone
How can I download earlier versions of STemWin library from ST website?
Best regards​
Update: Inside cubeIDE i´m still able to get them via "Help -> Embedded Software Packages Manager" :) If you don´t use cubeIDE, just install it, download the package, you need, find it on your hdd afterwards and make a copy :)
chaaalyy
Senior II
Normally they are contained inside the firmware packages for your mcu ... For F7 it´s:
https://www.st.com/content/st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32cube-mcu-mpu-packages/stm32cubef7.html
Scroll down and click on "select version".... As i just have seen, ST removed the older versions of these packages :( So maybe you find someone here, who still has an old one and can send it to you. Which one is needed ?
Ahaji.1
God bless you man ☺�? :tulip:​
