Font Wildcard range not accepted, or am doing something wrong
brianshankland9
I'm getting errors (image attached) reporting that characters are not part of the typographics.
For both fonts reported i have a range of 0x20-0x7e entered for wildcard range (also shown in attached image)
Cant run simulator or target while in this mode, what am I missing?
11 REPLIES 11
Hi @brianshankland9​,
I forgot where we ended up with this, other than i simply wasn't able to download your project. I was still just getting a blank page, despite your attempts to share.
Do you want to find another way to share? Maybe through WeShare. Are you still having this issue?
/Martin
Hi Martin, I kind of side stepped the problem as I realised I could not use Wingdngs fonts in any case as they are commercially protected ones. I was able to use other TT fonts including the standard wingdngs fonr but Wingdngs3 would not work for me even in a new project with only a single text field. Not sure if you can confirm that or not and I could share a smaller project if your can use it in your projects to find out what the cause (if any) in case it affects other fonts. regards _________________________________________________­_ Brian Shankland Icon Research Ltd 3 Raw Holdings | East Calder | West Lothian | EH53 0HY | UK T: +44 1506 885000 Ext 226 F: +44 1506 885501 www.iconresearch.co.uk<>
