Error when using custom widget.
‎2019-05-30 2:37 PM
Hey.
I'm trying to use a custom widget. Error:
Microsoft Visual C++ Runtime Library
Assertion failed!
Program: ...mulator\msvs\..\..\build\Debug\bin\Application.exe
File: ..\..\..\..\framework\source\touchgf...\CanvasWidget.cpp
Line: 40
Expression: canvasPainter != 0 && "No painter set"
For information on how your program can cause an assertion
failure, see the Visual C++ documentation on asserts
(Press Retry to debug the application - JIT must be enabled)
PS: Problem solved. Was my inattention
- Labels:
TouchGFX
‎2019-06-03 1:49 AM
Hi @Hosting​,
Glad you solved it. For everyone else, the problem was that no "Painter" was defined for the CanvasWidget. The Painter knows how to render to various depths of framebuffers. e.g. the PainterRGB565 class can render to 16-bit framebuffers in the RGB565 format.
/Martin
‎2019-06-03 1:49 AM
Hi @Hosting​,
/Martin
