error: #18: expected a ")" ?
antonius
Dear Members,
I got this error: #18: expected a ")"  on this line :
LCD_SendCommand(lcd_addr, 0b00110000);
")" is already there, what's the issue ??
5 REPLIES 5
Check if lcd_addr is correctly defined. But most likely there is an error in one of the previous lines (or included files) which causes an error to that correct line. Check for unterminated by ";" lines, unterminated quotation marks or parenthesis.
Binary is not accepted by most compilers.​
antonius
so better be in hex ?
antonius
LCD_SendCommand(lcd_addr, 0x30h); ?
Lose the h, you're programming in C​
0x30​
