PLaco.1
Visitor II
January 7, 2022
Data acquisition from adc with external clock with DCMI
  • January 7, 2022
  • 0 replies
  • 755 views
I have a NUCLEO-L4R5ZI. I try to test data aquisition by ST MCU from external clock at 10 MHz. I use DCMI interface.
In my test, I use a FPGA to generate clock and data connected to the Nucleo that includes DCMI interface. I did not succeed in going into HAL_DCMI_FrameEventCallback (I have connect FPGA clock to PA6 pin DCMI_PIXCLK). That means my buffer is not getting data from DMA. Do you why? Is there an error in my code ?
I attached my code.
Thank you,
Best regards,
Patrice
