Automation testing of TouchGFX based UI
Pritesh
Hi Team,
Is there any framework or lib support available from ST for automation testing of TouchGFX based UI either on simulator or on actual device?
If anyone has any idea or workaround, then please share!
JohanAstrup
Hello @Pritesh.
There is no framework provided by ST for doing that.
However, I know that one of our partners, Mjølner, works a lot with automated TouchGFX GUI testing and offers services in this area.
You can contact them to learn more.
Best regards,
Johan
@JohanAstrup Thanks for the update!
@Romain DIELEMAN I saw your old post for the same.
Can you share any data/steps for the same you did?
Thanks!
Hi Pritesh
Yes, we have been working on a UI test tool in Mjølner, like Johan said, which aims at fully automated tests that can even run on a CI server as part of the development process.
It is called Dvergr, and we tried to collect some technical information about it here: https://mjolner.dk/dvergr
Feel free to reach out if you would like to hear more about it :)
Kind regards
Bent Bisballe Nyeng
Mjølner Informatics A/S
