SBSFU Rollback with stm32L476RG
2024-12-30 8:50 PM
Hi All,
I am following the UM2262 document. I will add a screenshot. I enabled the ENABLE_IMAGE_STATE_HANDLING flag to enable rollback, but after updating UserApp.bin, the device continues to reset. I will add a debug log screenshot (it’s not jumping into the application). Please help me with any references for the rollback feature using the SBSFU package version 2.6.x.
Document image 1:
Debug image 2:
Raju
- Labels:
STM32L4 Series
2025-02-14 9:22 AM
Hi @Jocelyn RICARD ,
I have tested SBSFU Example with NucleoL476RG board with not setting compiler flag ENABLE_IMAGE_STATE_HANDLING .
1. I have flashed the Bootloader application and changing the firmware version from A,(version 1,1)B(version 1,2),C(version 1,3),D(version 1,4),E(version 1,5).
Working as Accepted.
2. When I have updated the ENABLE_IMAGE_STATE_HANDLING flag and commented the SFU_MPU_USERAPP_ACTIVATION macro .
Updating the version A (version1.1) ,B(version 1.2) works fine .
when i am trying to update the C(version 1.3) Facing issue i will add the log below please help me out this
DEBUG LOG:-
= (C) COPYRIGHT 2017 STMicroelectronics =
= Secure Boot and Secure Firmware Update =
= [SBOOT] SECURE ENGINE INITIALIZATION SUCCESSFUL
= [SBOOT] STATE: CHECK STATUS ON RESET
INFO: A Reboot has been triggered by a Hardware reset!
= [SBOOT] STATE: CHECK NEW FIRMWARE TO DOWNLOAD
= [SBOOT] STATE: CHECK USER FW STATUS
A FW is detected in the slot SLOT_ACTIVE_1
= [SBOOT] STATE: VERIFY USER FW SIGNATURE
= [SBOOT] STATE: EXECUTE USER FIRMWARE
= User App #A =
=================== Main Menu ============================
Download a new Fw Image ------------------------------- 1
Test Protections -------------------------------------- 2
Test SE User Code ------------------------------------- 3
Multiple download ------------------------------------- 4
Validate a FW Image------------------------------------ 5
Selection :
================ New Fw Download =========================
-- Send Firmware
-- -- Erasing download area ...
-- -- Programming Completed Successfully!
-- -- Bytes: 22736
-- Image correctly downloaded - reboot
= [SBOOT] System Security Check successfully passed. Starting...
INFO: A Reboot has been triggered by a Software reset!
New Fw to be installed from slot SLOT_DWL_1
= [SBOOT] STATE: INSTALL NEW USER FIRMWARE
Image preparation done.
Swapping the firmware images.....................................................
========= End of Execution ==========
= User App #B =
Selection :
-- Send Firmware
-- -- File> Transfer> YMODEM> Send
-- -- Bytes: 22736
AFTER UPDATING C (1.3VERSION)
Installation not validated: rollback procedure initiated (SLOT_ACTIVE_1 / SLOT_DWL_1)
= [SBOOT] STATE: ROLLBACK INSTALLATION TO PREVIOUS USER FIRMWARE
Backed-up fw not identified
Fw version rejected (anti-rollback)
= [SBOOT] STATE: HANDLE CRITICAL FAILURE
= [SBOOT] STATE: REBOOT STATE MACHINE
Slot SLOT_ACTIVE_1 not empty : erasing ...
No valid FW found in the active slots nor new FW to be installed
Waiting for the local download to start...
= [SBOOT] STATE: DOWNLOAD NEW USER FIRMWARE
File> Transfer> YMODEM> Send .........
Prakash
2025-02-19 7:12 AM
still No response
Prakash
2025-08-04 4:12 AM
This guidance works for me.
Thanks!
- « Previous
- 1
- 2
- Next »
