How to arrange encrypted key data in call to FUS_STORE_USR_KEY
crwper
AN5185 specifies that encrypted keys should use AES-128 GCM, but the format of data sent to FUS isn't very well specified:
Byte0: key type:
• 0x00: None
• 0x01: Simple key
• 0x02: Master key
• 0x03: Encrypted key
Byte1: key size N in bytes
Byte2 to ByteN-1: key data (key value + IV if any)
In particular, two things are not clear to me from this description:
  1. What format should the key data take, i.e., specifically how should the key value, tag, and IV be arranged in the data sent to FUS?
  2. What value should the key size take? The application note says Byte 2 to Byte N-1 are key data, but doesn't seem right at all, since it suggests a 16-byte key would have N = 18 (i.e., it would occupy bytes 2 through 17).
Specifically, for an AES-256 encrypted key (with 32 byte cyphertext, 16 byte IV, and 16 byte tag), what value should be in byte 1, and how should data be arranged in bytes 2 and up?
Thank you!
0 REPLIES 0
