where could I find any tutorial for STM32091C-EVAL/03-0?
SAbis
I just buy this eval Board and I am new in the world of MCU-Programming. For the board i bought they were not any document about how to use it. I install the MDK 5 ARM and wish to go stepwise through configuration and programming of the board.
Any link or document which can explain the use will be welcome.
Primary resources can be found here
https://www.st.com/en/evaluation-tools/stm32091c-eval.html
Example code can be found under the CubeF0 archives, secondary resources also listed on this page
https://www.st.com/en/embedded-software/stm32cubef0.html
STM32Cube_FW_F0_V1.9.0\Projects\STM32091C_EVAL\Demonstrations
STM32Cube_FW_F0_V1.9.0\Projects\STM32091C_EVAL\Examples
For training and seminars, check locally.
SAbis
Hi I am trying now to compile the BSP-example in "STM32Cube_FW_F0_V1.9.0\Projects\STM32091C_EVAL\Examples" but I am getting the error could not load 'STM32091C_EVAL\STM32091C_EVAL.axf' on the MDK-ARM.
Please more information about the problem..
Likely because the build process didn't complete without an error.
You can't load/debug something the linker hasn't built.
Look at the errors being reported during the build process.
