when we should use the OB_STOP_RST config in Option Bytes?
‎2024-11-14 6:38 PM
Hi there,
There is a config option named "OB_STOP_RST" that exists in Option Bytes' USERconfig, I tested it with STOP mode, and it works well.
But I can't understand when we should use it. After clearing this bit to OB_STOP_RST, the MCU will reset right away and enter run mode when it enters stop mode, why don't we just reset the MCU, it's easier and faster.
Same as the OB_STDBY_RST config.
- Labels:
STM32F1 Series
‎2024-11-15 2:43 AM
Hello @Junde,
This can be useful in scenarios where the system needs to ensure a clean start after waking up from STOP mode, avoiding any potential issues that might arise from an improper wake-up sequence or corrupted state
these OB provide a controlled way to handle low-power mode entries, instead of relying on external events or manual resets.
‎2024-11-15 2:43 AM
Hello @Junde,
‎2024-11-18 10:18 PM
I got it, thank you.
