2019-09-06 2:07 AM
2019-09-06 4:32 AM
You've selected the wrong make/model of debug pod.
You've connected it incorrectly to a device that doesn't work.
If you are using a device with an ST-LINK debugger, pick that in the debugger settings, select SWD or appropriate connection mode, and check that your device can be seen.
