Using DS3231 as OSC
beatloman91
The DS3231 MC has two open drain pins, SQW and SQW32, which can generate, respectively, 8Mhz and 32768 signals. Can I use these to start stm32s, sort of like an external generator? If so - those pins are open drain, what kind of pull-up resistors do I need?
0 REPLIES 0
