USART3 and Hard Fault exception handler
hassan_mj2
Posted on March 31, 2010 at 01:39
domen23
Posted on May 17, 2011 at 13:45
And the ISR handler is...? :p
It should also help to dump ''process stack'' when hard fault occurs.
Something in your code is writing or reading memory it should not be. For example writing data beyond the bounds of a buffer.
You have not presented enough code, for the functional portion, to pinpoint a particular problem.
-Clive
