USART1 Troubles
geoff2399
Posted on July 05, 2010 at 05:47
USART1 Troubles
4 REPLIES 4
domen23
Posted on May 17, 2011 at 13:57
Just to confirm my assumption... the code works with other usarts?
i should be volatile, or compiler can optimise out the delay loop.
geoff2399
Actually, now I have had a chance to connect a CRO to it, I am getting nothing via GPIO at all. Seems my .ld and .s is wrong for the toolchain, any hints on how to use ST Lib 3.3 with codesourcery?
geoff2399
Found the problem, was iterating an array with sizeof, not the number of elements... duh! *face palm*
geoff2399
Ok, got it working on USART3 but not 1 or 2, any thoughts?
