Undefined refference arm_math.h functions
Options
‎2016-05-05 6:46 AM
Posted on May 05, 2016 at 15:46
Hello there,
I am trying to use some functions from the arm_math.h library. The problem I am getting undefined reference to them. The compiler sees the structs from arm_math.h correctly though. I dont know what is the cause of this. I am using STM32F4, startup code is generated via mxCUBE. I cant use arm_mat_mult_f32 for example and etc. I would apreciate all help regarding this issue.
Options
‎2016-05-05 9:18 AM
Posted on May 05, 2016 at 18:18
An include file just defines the interface for the compiler, you still have to add the objects/libraries with the code into your project for the linker to bind them.
Options
‎2016-05-05 9:25 AM
Posted on May 05, 2016 at 18:25
I know, I can see the c files in the project folders but for some reason couldnt link them. I had to create a new folder in eclipse and move all c files there. Thanks.
