UART Registers Documentation for STM32F429xx? Where is it?
gustavo23
Posted on April 09, 2015 at 04:40
Where can I find documentation on the UART registers for the STM32F429xx micro?
The datasheet ( http://www.st.com/web/en/resource/technical/document/datasheet/DM00071990.pdf ), does not include any information about it.
The same goes for any other peripheral, there doesn't seem to be much in depth discussion about then in the datasheet; I assume I am missing something, and that it must be documented somewhere else.
#lmgtfy:-stm32-resources
5 REPLIES 5
childresss
Posted on April 09, 2015 at 06:04
It's all there in the user manual documents.
But the HAL code does all this low level I/O based on your use of the APIs.
And you can (should) use CubeMX to auto-generate all the I/O initialization and ISRs.
Posted on April 09, 2015 at 06:11
Like a
http://www.st.com/web/en/resource/technical/document/reference_manual/DM00031020.pdf
gustavo23
Posted on April 09, 2015 at 15:51
That is exactly what I was looking for, that Reference Manual.
BTW, I am using the CubeMX library, but the documentation of the CubeMX is not enough to really understand the peripheral it manages; so to me at least this Manual is critical.
childresss
Posted on April 10, 2015 at 02:45
RM0090
Reference manual
STM32F405/415, STM32F407/417, STM32F427/437 and
STM32F429/439 advanced ARM®-based 32-bit MCUs
Easy to find with a brief web search
gustavo23
Posted on April 11, 2015 at 20:26
Thank you Steve, you are so helpful.
