2025-10-20 4:20 AM
I've been reviewing the documentation for the STM32WBA55, but I haven’t found a clear answer on whether it is possible to directly access the RF registers to tune to a specific RX channel (ex. 2450MHz) and measure the channel's RSSI - specifically, without relying on any protocol-specific signal like Bluetooth LE. Could you please clarify if this is supported? Thank you.
2025-11-24 4:10 AM
Hello @ugniues,
for this purpose, you can use STM32WBA55 Phy_Cli example
If you need any help with the example, please let me know
Best regards,
grohmano
2025-11-24 4:10 AM
Hello @ugniues,
Best regards,
grohmano
2025-12-04 2:53 AM - edited 2025-12-05 3:24 AM
Found the solution. Thank you.
