Timer External Clock
jveith
Posted on May 07, 2011 at 12:38
mehmet.karakaya
Posted on May 17, 2011 at 14:34
dont waste your time trying to count ETR pulses
no matter what I tried I couldnot count ETR pulses
There must be a hardware bug
try counting CH1 pulses instead
jveith
The reason for not counting was a cold solder junction at the enameled copper wire what does the modification of PCB from T2-CH4 to T3_ETR pin. As soon as there is a signal with edges at the ETR pin, the above posted code increments the counter like expected.
Try the code from above and check your ETR pin for present pulses. If they are missing, there must be a hardware bug...
